Stylus check during CNC start
Hi all,
Every so often, the settings for Stylus check during CNC start revert back to "No check" which then allows operators to potentially run programs using un-calibrated styli. Typically, this setting is set to "Cancel" and we cannot figure out how or why it is being changed erratically back to the default. Has anyone else experienced this issue? We have several CMMs in our facility that require manually turning these settings back on each time. Is there a fix?
Cheers,
Don
