Mesh edit
Hello,
I want to cut a mesh in a specific area , in this example i made a cylinder based section and I don't know what option should I use. Can this be done if i select 4 areas once and remain only with those parts from the mesh? Thanks
Hi Florin,
Do you use CAD? I usually use Select By Mesh.
You can select your CAD and give an offset, if there is points out of this offset it will be not selected, after you just need to invert the selection and delete the mesh.
