Alignment names in characteristic list
Is there a way to capture all the names of the alignments in the characteristic list?  I can generate a list of all the characteristic names, but the alignment names are not on the list.
Try this ..
 This will output them all to a .txt file in your program folder.
for i =1 to baseSystem().machine.inspection.allPCSNames.size
	coordsysnames=getParameterNamed(baseSystem().machine.inspection.allPCSNames.asArray,i).asString
	addToFile(getActualInspectionDir()+"\PCM1.txt", coordsysnames)
next i
I'm learning slowly ..
if you just want the names :
Edited
baseSystem().machine.inspection.getExistingPCS.definitionList  // usage and elements
baseSystem().machine.inspection.getExistingPCS.definitionList2 // usage and elements without ' -> '
baseSystem().machine.inspection.getExistingPCS.allMeasElementNames // only elements
bas=baseSystem().machine.inspection.getExistingPCS.definitionList
for i=1 to bas.keys.size
    el=getParameterNamed(bas,i)
        display(el.key.trim + "   ->   " + el.value.trim)
          next i
Edited
