[Se...] Posted December 11, 2024 Share Posted December 11, 2024 (edited) Hello, Is there a way to change what gets printed on a report, based on a previous measurement, for example, if a diameter made of 8 points is OUT of tolerance, only then will the 8x Polar Radii been present on the report too. If the diameter is in tolerance, the 8x Polar Radii DO NOT appear on the report? I do not have PCM. Thanks in advanced. Edited December 11, 2024 Link to comment Share on other sites More sharing options...
[Ün...] Posted December 12, 2024 Share Posted December 12, 2024 If you want to see only out-of-tolerance values in the report, you can try this Link to comment Share on other sites More sharing options...
[Se...] Posted December 13, 2024 Author Share Posted December 13, 2024 Unfortunately not, if the diameter is out of tolerance, only then do I want to see the 8x points that make up the circle! Link to comment Share on other sites More sharing options...
