[Cl...] Posted December 12, 2024 Share Posted December 12, 2024 When a new program is created, and features are extracted. For example, you extract a circle and, in the strategy, there are default point spacing, speed, etc. Are those values recommended default. Or are the arbitrary? Link to comment Share on other sites More sharing options...
[Ün...] Posted December 12, 2024 Share Posted December 12, 2024 I know that the scanning speed increases as the diameter value increases. I think the dot spacing changes accordingly. Link to comment Share on other sites More sharing options...
[Ma...] Posted December 12, 2024 Share Posted December 12, 2024 You can change the default strategies for various feature types under Resources-Save/Load Defaults. I don't know if a new install of the software has any defaults set or not. Link to comment Share on other sites More sharing options...
[Cl...] Posted December 12, 2024 Author Share Posted December 12, 2024 I was just curious why those values populated the new feature. Link to comment Share on other sites More sharing options...
[Ma...] Posted December 25, 2024 Share Posted December 25, 2024 This is something I’d like to see added to Calypso, the writers of the Cookbook. When a feature is scanned and filter and outliers applied why can’t Calypso set the evaluation automatically based on the nominal of size, probe radius, etc… They have this information and they should be able to apply it and let the programmer change if needed. Link to comment Share on other sites More sharing options...
[Je...] Posted December 26, 2024 Share Posted December 26, 2024 Clarke, I don't think the values are arbitrary, but they have definitely been set in favor of cycle time. I use custom defaults for scanning speed and point density. The out-of-the box defaults are a bit faster and less dense in point spacing than what I've found to provide the most stable, balanced result for our processes. Link to comment Share on other sites More sharing options...
[Ri...] Posted January 3, 2025 Share Posted January 3, 2025 Please sign in to view this quote. How do you setup your defaults? I have never bothered to do this, always edit on the fly. Link to comment Share on other sites More sharing options...
[Ri...] Posted January 3, 2025 Share Posted January 3, 2025 I would be curious to see users ".all" (Save/Load default files) files to see what you are using for default setups. Link to comment Share on other sites More sharing options...
[Ri...] Posted January 3, 2025 Share Posted January 3, 2025 Question: If I load a default file, will it change all settings in my program? I have many features/characteristics that use specific settings. Link to comment Share on other sites More sharing options...
[ja...] Posted January 3, 2025 Share Posted January 3, 2025 Please sign in to view this quote. it shouldn't overwrite your strategies for already created features; it just sets them for newly created features. Please sign in to view this quote. in Extras -> Settings -> Measurements there are some settings to play with. in Extras -> Settings -> Variable Strategy Editor, you can also create a list of rules to assign different strategies for features depending on their dimensions, e.g. "if the length & of this cylinder is less than the diameter & under 5mm, use 1 circle path" or whatever. Link to comment Share on other sites More sharing options...
