Accessing mesh data arrays
Hello support team,
I am writing a custom filter for a special application and I would like to have it written using functions avalaible in numpy, as it we have to process big amounts of points.
My question : how can I select a list of triangles on the mesh? (Or even better : maybe delete them directly from the mesh?)
Actually I am aware of the fonction gom.script.selection3d.select_triangle (point=gom.Vec3d()).
I would need something like gom.script.selection3d.select_triangles (triangles=[np.array (gom.app.project.parts[0].actual.data.triangle[0:2500]])
or like gom.script.selection3d.select_triangles (points=[list of gom.Vec3d])
Do not hesitate if you need me to rephrase the question.
BR
Benjamin
  • 2 weeks later...
I would suggest something like:
# -*- coding: utf-8 -*-
import gom
import numpy as np
CURRENT_STAGE = gom.app.project.get ('stage.index')
def SelectTriangles (mesh_element, tris):
	pts = np.array (mesh_element.data.coordinate)[CURRENT_STAGE]
	tri_pts = np.mean (pts[tris], axis=-2)
	gom.script.selection3d.deselect_all ()
	gom.script.cad.show_element_exclusively (elements=[mesh_element])
	for tri_pt in tri_pts:
		gom.script.selection3d.select_triangle (point=gom.Vec3d (tri_pt[0], tri_pt[1], tri_pt[2]))
if __name__ == '__main__':
	mesh_element = gom.app.project.parts[0].actual
	tris = np.array (mesh_element.data.triangle)[CURRENT_STAGE]
	SelectTriangles (mesh_element, tris[:10])
  • 2 weeks later...
Thanks Theodor,
I will test it and give you some feedback.
Have a nice day.
Benjamin
