[Be...] Posted May 12, 2021 Share Posted May 12, 2021 Hello support team, I am writing a custom filter for a special application and I would like to have it written using functions avalaible in numpy, as it we have to process big amounts of points. My question : how can I select a list of triangles on the mesh? (Or even better : maybe delete them directly from the mesh?) Actually I am aware of the fonction gom.script.selection3d.select_triangle (point=gom.Vec3d()). I would need something like gom.script.selection3d.select_triangles (triangles=[np.array (gom.app.project.parts[0].actual.data.triangle[0:2500]]) or like gom.script.selection3d.select_triangles (points=[list of gom.Vec3d]) Do not hesitate if you need me to rephrase the question. BR Benjamin Link to comment https://qualityforum.zeiss.com/topic/215-accessing-mesh-data-arrays/ Share on other sites More sharing options...
[Th...] Posted May 27, 2021 Share Posted May 27, 2021 I would suggest something like: # -*- coding: utf-8 -*- import gom import numpy as np CURRENT_STAGE = gom.app.project.get ('stage.index') def SelectTriangles (mesh_element, tris): pts = np.array (mesh_element.data.coordinate)[CURRENT_STAGE] tri_pts = np.mean (pts[tris], axis=-2) gom.script.selection3d.deselect_all () gom.script.cad.show_element_exclusively (elements=[mesh_element]) for tri_pt in tri_pts: gom.script.selection3d.select_triangle (point=gom.Vec3d (tri_pt[0], tri_pt[1], tri_pt[2])) if __name__ == '__main__': mesh_element = gom.app.project.parts[0].actual tris = np.array (mesh_element.data.triangle)[CURRENT_STAGE] SelectTriangles (mesh_element, tris[:10]) Link to comment https://qualityforum.zeiss.com/topic/215-accessing-mesh-data-arrays/#findComment-654 Share on other sites More sharing options...
[Be...] Posted June 7, 2021 Author Share Posted June 7, 2021 Please sign in to view this quote. Thanks Theodor, I will test it and give you some feedback. Have a nice day. Benjamin Link to comment https://qualityforum.zeiss.com/topic/215-accessing-mesh-data-arrays/#findComment-713 Share on other sites More sharing options...
