[na...] Posted December 18, 2024 Share Posted December 18, 2024 I'm trying to imagine would it make sense and what would the workflow be using git to manage Calypso plan revisions. Anyone tried? Or any feedback of Calypso built-in versioning? Link to comment Share on other sites More sharing options...
[Ri...] Posted December 18, 2024 Share Posted December 18, 2024 I use the plan name by adding a date to the end of the name. 3032943-202_A_OP35_04-15-2024 3032943-202 = Part Number A = Revision level of part OP35 = Operation number 04-15-2024 = Revision control of CMM program Then I use an excel workbook for setup information which is named the same as the plan name with a "#" prefix (This keeps the workbook at the top of the list). The workbook is stored in the plan name folder. #3032943-202_OP35_04-15-2024.xlsx The workbook has a worksheet named Rev History; this is where all changes are documented. Feel free to use the workbook attached. #Master CMM Setup workbook 2023.xlsx Link to comment Share on other sites More sharing options...
[Ma...] Posted December 18, 2024 Share Posted December 18, 2024 We are using that - only thing which will come into mind will be current state of program. You can recall previous versions, but that will destroy "current working version". You can make in autorun to call specific version, but i think it have some problems with using different versions simultaneously. That function make changes in program directory. Link to comment Share on other sites More sharing options...
[na...] Posted December 19, 2024 Author Share Posted December 19, 2024 Thank you both, Martin I didn't know recall version works, so I would just make a copy and keep the latest vesrion separate. I have to try it out sometime soon. 1 thing I don't see anywhere, comparing to git (or similar versioning system) is when you make specific changes in rev. 1.5, you cannot port them to lower version. Like there are no "branches". Link to comment Share on other sites More sharing options...
[Ma...] Posted December 19, 2024 Share Posted December 19, 2024 Please sign in to view this quote. Here it works like saving plans into different folders. So no branches, only saved revisions and working copy. Link to comment Share on other sites More sharing options...
[Wo...] Posted December 19, 2024 Share Posted December 19, 2024 It would be nice to have at least a built-in change log so you could quickly look up what was modified in the plan. Link to comment Share on other sites More sharing options...
[Ri...] Posted December 19, 2024 Share Posted December 19, 2024 If you use Local Versioning, you can easily compare different versions. 🙂 CALYPSO: How To Set Up Measurement Plan Versioning Comparing Different versions of CALYPSO Inspection Plans Link to comment Share on other sites More sharing options...
[Ri...] Posted January 3, 2025 Share Posted January 3, 2025 Please sign in to view this quote. Edit: When a file revision is complete the old file gets renamed with a suffix. "-History 01.01.25 RS" "-History" (States the file is placed in the History folder.) "01.01.25" (Date of revision change.) "RS" (User initials.) Example: 3032943-202_A_OP35_04-15-2024 becomes 3032943-202_A_OP35_04-15-2024-History 01.01.25 RS Link to comment Share on other sites More sharing options...
