[Ky...] Posted December 18, 2024 Share Posted December 18, 2024 Hi I am researching glove fit using the distance of the glove exterior and interior. Using deviation label, I am able to get the gap between the exterior and interior of the glove. However, it calculates the difference from the external glove surface to the internal glove surface. Is there a way to calculate it starting from the internal surface of the external glove (excluding the thickness of the outer fabric) to the interior glove surface? I attached some picture for easier understanding. Link to comment Share on other sites More sharing options...
[Na...] Posted January 22, 2025 Share Posted January 22, 2025 Hello Kyurey, this should be possible with a general surface distance, where the two surfaces can be defined by a selection. In 2D with two sections (also defined by selection). But I think this is should be analyzed with the concrete data set, so I recommend to reach out to your local support with the project. Nanno Link to comment Share on other sites More sharing options...
