[Cl...] Posted December 18, 2024 Share Posted December 18, 2024 This program measures a family of 12 parts. All geometry the same, with varying diameters. Below are my presetting's. Same as I always use. I've never had this problem before. Program runs fine but the model doesn't even appear to get loaded into the program. Its got to be something simple, but I can't figure it out. All the models are in the program folder and their names match the PCM Presetting's below. LN = getRecordHead("order") clearCAD() dir = getActualInspectionDir() Part_Size = inquireList("Which part number are you measuring?", "100420", "120100", "119270", "120028", "114184", "114185", "117403", "105723", "113003", "111460", "119271", "110920") selectCase Part_Size case "100420" readPCMFile(dir + "\100420.PARA") loadCADFile(dir+"\.100420.sab") Link to comment https://qualityforum.zeiss.com/topic/21552-cad-model-disappears/ Share on other sites More sharing options...
[Th...] Posted December 18, 2024 Share Posted December 18, 2024 Is the leading dot for your CAD load supposed to be there? \.100420 instead of \100420? Link to comment https://qualityforum.zeiss.com/topic/21552-cad-model-disappears/#findComment-122870 Share on other sites More sharing options...
[Cl...] Posted December 19, 2024 Author Share Posted December 19, 2024 Yes, the "dot" is supposed to be there. Link to comment https://qualityforum.zeiss.com/topic/21552-cad-model-disappears/#findComment-122896 Share on other sites More sharing options...
[Cl...] Posted December 19, 2024 Author Share Posted December 19, 2024 I thought it was initially. I use premade PCM templates. The one I used for this had a period added somehow by mistake. Link to comment https://qualityforum.zeiss.com/topic/21552-cad-model-disappears/#findComment-122914 Share on other sites More sharing options...
