Shutting off parts of 3D model for Inspection
I haven't used Calypso in a few years and wondering if there is something to turn on/off parts of a 3D model that has been loaded. My question is checking a Gage Fixture and i had the engineer send me the step file with part included on model. I am just curious if there is something to turn the part off so as to program the Fixture and then turn on the part and start picking up the rest of dimensions. I am asking just because not sure if anything like this is achievable? Thanks from an old 2D print programmer!
yes this can be done manually and kind of with PCM Code, PCM will clear it or erase/delete it, but can be re-loaded.
 To do it manually, go to CAD>Modify CAD Entities>Heirarchy and uncheck what you dont want to see. You may be able to go to edit body , select your CAD with mouse, and select hide feature.
Good luck.
