Uninstall help
Hello,
please make sure nothing is left in C:\Program Files\Zeiss\INSPECT\2025
Then open the registry editor (WIN +R -> regedit or open it from the apps) and navigate to Computer\HKEY_LOCAL_MACHINE\SOFTWARE\GOM\2025 and delete the folder. There is also a folder Computer\HKEY_LOCAL_MACHINE\SOFTWARE\Zeiss\INSPECT\2025, which you might have to delete.
Then you should be able to run the installer again. Please run it as administrator.
Nanno
https://qualityforum.zeiss.com/topic/21558-uninstall-help/#findComment-122972
