Read all file names in a directory?
I want to make a parametric program, that I can edit entirely outside of the program...
Is there a function that simply will give me all the file names in a directory? Basically, can I read these 3 files and get them in a list?
or is this going to be something that needs done with getParameterNamed() and a loop?
Im sure these is, I will search when I have some time..
Question : if you're making the parametric program, do you just want to check to make sure these 3 files exist ?
fileExists()
Is it important for the program to know if there are more files or you just want to check to make sure ?
