[Do...] Posted December 23, 2024 Share Posted December 23, 2024 I am looking to measure the distance from one plane to another in the same orientation (z+). I am using a cartesian distance characteristic and I can obtain different results based on which evaluation method I choose for the planes (LSQ, Outer Tan, Min Fea, etc.) How do these evaluation methods apply to planes exactly? If both planes are set to LSQ, is that the best average between the two? If I wanted to know the minimum and maximum difference between them, would I set the upper plane to outer tan and the lower plane to minimum feature and vice versa? What are the best and most common methods to report this distance? Cheers, Don Link to comment https://qualityforum.zeiss.com/topic/21582-plane-evaluation-methods/ Share on other sites More sharing options...
[Ma...] Posted December 24, 2024 Share Posted December 24, 2024 Best to use caliper distance. to understand Cartesian Distance watch this video https://youtu.be/95eUwyPyAVM Link to comment https://qualityforum.zeiss.com/topic/21582-plane-evaluation-methods/#findComment-123034 Share on other sites More sharing options...
[Ja...] Posted December 26, 2024 Share Posted December 26, 2024 This attachment might help. Although it could be overkill for your application, it should help explain the evaluation settings. I have found the distance between one plane set to outer tangent and the second plane set to LSQ seems to give me more realistic results. The distance between two planes both set to outer tangent tends to give me a high reading that I can't replicate with any other measurement tools. LNL_Distance.pdf Link to comment https://qualityforum.zeiss.com/topic/21582-plane-evaluation-methods/#findComment-123044 Share on other sites More sharing options...
