[Cl...] Posted December 27, 2024 Share Posted December 27, 2024 I don't know much or use planner very often. Can a .PCF probe file be converted into an .SSC probe file. Link to comment https://qualityforum.zeiss.com/topic/21590-plannersimulation/ Share on other sites More sharing options...
[Cl...] Posted December 27, 2024 Author Share Posted December 27, 2024 (edited) Please sign in to view this quote. Edited December 27, 2024 Link to comment https://qualityforum.zeiss.com/topic/21590-plannersimulation/#findComment-123064 Share on other sites More sharing options...
[Ma...] Posted December 27, 2024 Share Posted December 27, 2024 I use Planner all the time and I'm not aware of how to convert it. I don't think it would be possible. When you bring in a .PCF you get a 'stick and ball' so Calypso doesn't know in you used the 11mm or 20mm extension diameter, or a Renishaw configuration and not a Zeiss configuration, etc... Link to comment https://qualityforum.zeiss.com/topic/21590-plannersimulation/#findComment-123068 Share on other sites More sharing options...
[Ri...] Posted January 3, 2025 Share Posted January 3, 2025 As far as I know, you can only create SSC files in Stylus System Creator. Link to comment https://qualityforum.zeiss.com/topic/21590-plannersimulation/#findComment-123234 Share on other sites More sharing options...
[No...] Posted January 7, 2025 Share Posted January 7, 2025 That is correct. The PCF file contains only the basic probe dimensions (X,Y,Z, tip radii...) and stylus names. The SSC on the other hand is actually a ZIP in disguise which contains additional (proprietary) model files for each element. Link to comment https://qualityforum.zeiss.com/topic/21590-plannersimulation/#findComment-123406 Share on other sites More sharing options...
