[An...] Posted December 30, 2024 Share Posted December 30, 2024 Hi Zeiss Community, I'm working on developing a master measurement program for bike sprockets using PCM in Zeiss Calypso software. Since all bike sprockets share the same design with only dimensional variations, I want to create a single program that can measure error deviations by adjusting variable parameters. Could anyone provide guidance or share their experience on how to set up such a program in Zeiss Calypso? Any tips or resources would be greatly appreciated. Thank you! Link to comment Share on other sites More sharing options...
[Cl...] Posted December 30, 2024 Share Posted December 30, 2024 (edited) So, part to part the geometry is exactly the same? If the only difference is the size changing part to part this is very easy. Presetting's _______________________________________________________________________________________________________________________________ LN = getRecordHead("order") clearCAD() dir = getActualInspectionDir() Part_Size = inquireList("Which part number are you measuring?", "123456", "123457", "123458") selectCase Part_Size case "123456" readPCMFile(dir + "\123456.PARA") loadCADFile(dir+"\123456.sab") case "123457" readPCMFile(dir + "\123457.PARA") loadCADFile(dir+"\123457.sab") case "123458" readPCMFile(dir + "\123458.PARA") loadCADFile(dir+"\123458.sab") endSelect Edited December 30, 2024 Link to comment Share on other sites More sharing options...
[Cl...] Posted December 30, 2024 Share Posted December 30, 2024 Para file example. 123456.PARA Link to comment Share on other sites More sharing options...
[An...] Posted December 31, 2024 Author Share Posted December 31, 2024 No! part to part geometry is not same. Specifications as given in image that varies part to part. is it possible to fit a pin of given diameter in all teeth profile using pattern? Please sign in to view this quote. Link to comment Share on other sites More sharing options...
