running ZEISS Inspect in silent mode
Hello everyone,
I have an application which uses an .exe file to trigger and run the python script developed in ZEISS Inspect 2022.
I need to run the ZEISS Software  in silent mode  during the process without opening project templates for recalculation task etc. Is it possible to make such things happen in 2022 version?
I would like to underline that what I mean from silent run is main operating mode not the installation mode.
Thanks,
Canset
Hello Mathias,
I checked the starting options but couldn't find what I'm looking for.
What I want to ask is basically is it possible to run the ZEISS Inspect without displaying its UI  when performing a simple recalculation task?
If running ZEISS app without displaying its GUI is possible (in another way of saying starting the software in the background), then I need to find a way to do that.
Thanks,
Canset
Hi
I'm afraid ZEISS INSPECT cannot be executed without GUI.
Best regards,
Matthias
Hello Matthias,
Actually, the reason why we need silent operation is the periodic sign-out of the user.
The user account which runs the Python script and exe should sign-out periodically due to security concerns. In that case, I need to make sure that my script still continue to work and perform inspection.
We thought that it may require silent operation to ensure script working but maybe you can offer something different to solve this problem.
Thanks,
Canset
Caffine.exe
you could also try to 'switch users' instead of 'sign out' to keep the background task operating...
