Can I get some help with drawing?
Hello.
Is there anyone who can help me with this drawing?
I've used only standard alignment....I have no idea how to measure it
I tried to set base alignment with P6 and RPS.
P6: not allowed to choose more than 3 features, so failed
RPS 321: not allowed to more than 6 features, failed.
1. Should I use RPS Freedom?
2. Target datum A is a center of hole...
Use working plane function to get a center of hole projected onto upside plane??
3. To measure true position 0 (2 points), what features should I inspect??
https://qualityforum.zeiss.com/topic/21628-can-i-get-some-help-with-drawing/
If you have a bunch of these to run, i would continue to use standard alignment.
I would use a plane Line Line on the bottom side, Maybe even add in a loop (I almost always loop 2 times) and then once your machine knows the part you can scan your datum B & C later on in the program.
The reason i would do that is your datums are 3mm holes, so you're probably going to be using a 1mm styli, and those aren't very durable for poking around and finding stuff.
