[Ja...] Posted January 2, 2025 Share Posted January 2, 2025 Hello. Is there anyone who can help me with this drawing? I've used only standard alignment....I have no idea how to measure it I tried to set base alignment with P6 and RPS. P6: not allowed to choose more than 3 features, so failed RPS 321: not allowed to more than 6 features, failed. 1. Should I use RPS Freedom? 2. Target datum A is a center of hole... Use working plane function to get a center of hole projected onto upside plane?? 3. To measure true position 0 (2 points), what features should I inspect?? Link to comment Share on other sites More sharing options...
[Ro...] Posted January 2, 2025 Share Posted January 2, 2025 If you have a bunch of these to run, i would continue to use standard alignment. I would use a plane Line Line on the bottom side, Maybe even add in a loop (I almost always loop 2 times) and then once your machine knows the part you can scan your datum B & C later on in the program. The reason i would do that is your datums are 3mm holes, so you're probably going to be using a 1mm styli, and those aren't very durable for poking around and finding stuff. Link to comment Share on other sites More sharing options...
