Remove tolerances from TruePosition coordinates?
I thought I did this once before and I can't recall how.\
I want to remove the tolerances from true positions. Profiles. Concentricity, etc from the displayed coordinates when "Additional Report" is enabled.
Characteristics settings, turn off.
But then I also see it turns off plot for Tolerance of Position, which I really don't like and I hope Carl will change.
I think this filter should work to remove those from the displayed report without killing the associated plots:
${if AnyOf(AnyOf(Equal(String.Right(Qdb.Characteristic(2002),2),".X"),Equal(String.Right(Qdb.Characteristic(2002),2),".Y")),Equal(String.Right(Qdb.Characteristic(2002),2),".Z")) then "" else Qdb.Characteristic(2113)}
  • 1 month later...
Will the code from Thomas also prevent the affected characteristic from being flagged as out of tolerance?
No, it doesn't. I had to find my Piweb training book to remember any of this, but it's just a variable expression that replaces the one used in the default row template's upper tolerance text element. Not even really a filter, I guess. Same for the lower tolerance except the attribute number is 2112 instead of 2113. All it does is hide the values in the report.
  • 2 weeks later...
