Filter and other options in evaluation.
I defined a circle Ø160 on machined bore, and reported roundness 0.088, but when I checked roundness by Marposs gauge, it measured 0.027.
Should I have to use filter and other options in evaluation.
Yes, as a general statement. Applying the circular algorithm LSQ, MI, MC, etc… is something else to consider
Yes, you should use filters and outliers.
Also, devices that measure with 2 opposing pins, such as Marposs, usually show low roundness values.
This varies depending on the processing method of the part
