[Jo...] Posted January 7, 2025 Share Posted January 7, 2025 Hello all, I'm looking to see if anyone has a PCM command list they could share. I appreciate the help! Thanks, JG 1 Link to comment Share on other sites More sharing options...
[DW...] Posted January 7, 2025 Share Posted January 7, 2025 Please sign in to view this quote. Open the help file and search "PCM quick reference" Link to comment Share on other sites More sharing options...
[Ne...] Posted January 7, 2025 Share Posted January 7, 2025 Is some admin able to pin a thread with the answer to this much-repeated question to always be on top? Would be beneficial to all. Link to comment Share on other sites More sharing options...
[Mi...] Posted January 8, 2025 Share Posted January 8, 2025 https://forums.zeiss.com/messtechnik/community/viewtopic.php?p=57572&hilit=funktionsliste+PCM#p57572 Link to comment Share on other sites More sharing options...
[Jo...] Posted January 8, 2025 Author Share Posted January 8, 2025 Thanks All! Link to comment Share on other sites More sharing options...
[Ch...] Posted March 10, 2025 Share Posted March 10, 2025 This Link doesnt work: https://forums.zeiss.com/messtechnik/community/viewtopic.php?p=57572&hilit=funktionsliste+PCM#p57572 Link to comment Share on other sites More sharing options...
[Ma...] Posted March 10, 2025 Share Posted March 10, 2025 Try here Link to comment Share on other sites More sharing options...
[Je...] Posted May 13, 2025 Share Posted May 13, 2025 Here you go. Zeiss Calypso PCM Commands List.pdf 3 1 Link to comment Share on other sites More sharing options...
[To...] Posted May 13, 2025 Share Posted May 13, 2025 Please sign in to view this quote. have you just dropped the glove for Lord Calypso? 1 Link to comment Share on other sites More sharing options...
[Ca...] Posted June 18, 2025 Share Posted June 18, 2025 The reference Jeff gave is fantastic!! There's also the Calypso_02_pcm.pdf that installs with every version of CALYPSO here for CALYPSO 2024: C:\Program Files\Zeiss\CALYPSO 7.8\userinfo\manuals\en-US - It is useful to be able to search through to find examples and reference. 1 Link to comment Share on other sites More sharing options...
[Ri...] Posted July 2, 2025 Share Posted July 2, 2025 Any reason I can no longer download Please sign in to view this username. 's attachment? 1 Link to comment Share on other sites More sharing options...
[Je...] Posted July 3, 2025 Share Posted July 3, 2025 I still can... anyway: Zeiss Calypso PCM Commands List.pdf 1 Link to comment Share on other sites More sharing options...
[Je...] Posted July 4, 2025 Share Posted July 4, 2025 Hi Please sign in to view this username. , That's a great question for Please sign in to view this username. to answer. I don't know why the PCM command list excel file is no longer downloadable. I'm quite certain that what I shared was my own knowledge resource and should not be restricted. Link to comment Share on other sites More sharing options...
[Fa...] Posted October 10, 2025 Share Posted October 10, 2025 Maybe u also looking for that PCM Command? That's the list if geeting in Oberkochen from some measurement technician it is not the newest one, but the one for Calypso 7.6 Funktionsliste_PCM_2023_7.6_DE.pdf 2 1 Link to comment Share on other sites More sharing options...
[Ri...] Posted December 15, 2025 Share Posted December 15, 2025 Please sign in to view this quote. For those who have a slightly different install: (Example) C:\Program Files (x86)\Zeiss\CALYPSO 7.4\userinfo\manuals\en-US 1 Link to comment Share on other sites More sharing options...
[Sv...] Posted February 6 Share Posted February 6 Is there also a list of which commands work without a PCM license? 1 Link to comment Share on other sites More sharing options...
[Jo...] Posted February 6 Author Share Posted February 6 (edited) Please sign in to view this username. Not 100% sure, as I have always had the PCM Lic. I believe any strings you can place in the formula window, as well as the condition window, is apart of the free PCM. You should also be able to place if/then logic statements here as well. I believe you are locked out of the Pre/Post setting PCM areas and functions as well. Edit: This also works within result elements as well. Edited February 6 Link to comment Share on other sites More sharing options...
[Ri...] Posted 9 hours ago Share Posted 9 hours ago (edited) Please sign in to view this quote. Kind of locked out. If you have a seat with a PCM license you can add code to the Pre and Post settings. Then when in a non-PCM seat, you can edit the PCM code in the inspset file. I add search words, like "PRE PCM CODE HERE". You can then search for the words and edit as needed. Do something similar to Post settings. I can read and write files on non-licensed PCM seats. //For Calypso without PCM license. //Search words PN=getRecordHead("drawingno") //automated part no. "Drawing No." must be set in "Select report header parameters" 12.23.25. setRecordHead("u_PartNumb",PN) // OpWoID=getRecordHead("order") OpPartNumb=getRecordHead("u_PartNumb") OpFam=getRecordHead("planid") //Program ID // inspPath = getActualInspectionDir()+"\" fileName = "setRunID2.txt" deleteFile(inspPath+fileName) addToFile(inspPath+fileName, OpPartNumb) addToFile(inspPath+fileName, OpWoID) addToFile(inspPath+fileName, getRecordHead("dmesn") ) fileName = "setRunID3.txt" inspPath = getActualInspectionDir()+"\" deleteFile(inspPath+fileName) addToFile(inspPath+fileName, getRecordHead("dmesn") ) //End New You can test code by entering the code in Pre settings. Then disable the PCM license and test. Edited 9 hours ago Link to comment Share on other sites More sharing options...
