[Cl...] Posted January 8, 2025 Share Posted January 8, 2025 I only really use planner to create new programs offline. Importing and using the existing PCF files from the live machine. I have created a few styli in the past, but generally I don't use the stylus creator. I have on one machine (RDS/XXT) nine different stylus systems (configurations). Some of these systems have as many as 20 different angles/rotations. So, there are hundreds of these angles/rotations. If I were to create SSC files for each of these systems, would I have to create a stylus for each rotation/angle? Also do I need to start the creation of each system with the RDS and XXT components or just start with the adapter plate? Thanks in advance. Link to comment Share on other sites More sharing options...
[To...] Posted January 9, 2025 Share Posted January 9, 2025 (edited) Please sign in to view this quote. Hey Clarke, maybe this will help you understand the process better. Also, you need to create the entire RDS adapter, sensor combo with each new one. Shortcut: after you save one, delete the components up to the adapter plate and add the new components BUT DON'T HIT SAVE YET. There will be an icon regarding the properties where you change the name to the new system, then hit save. Stylus System Transfer.pdf Edited January 9, 2025 Link to comment Share on other sites More sharing options...
[Cl...] Posted January 9, 2025 Author Share Posted January 9, 2025 Thanks Tom. Do I have to create each angle/rotation as well? Link to comment Share on other sites More sharing options...
[To...] Posted January 9, 2025 Share Posted January 9, 2025 (edited) Please sign in to view this quote. Yes, you do, but not in SSC. The "stylus system transfer" attachment that I included, describes the process. Edited January 9, 2025 Link to comment Share on other sites More sharing options...
