End Part Position Ignored in Geometry Re-Qualification Program
If you have PCM you can put a positionCMM() command in the post settings for the program.
I actually have positionCMM(450.0,-125.0,-50.0) in an inspection_end_pcm.txt so it runs on all programs so every single one of my programs goes up to a safe place without having to edit the park position in everything. Those values are for a DuraMax to put it near the back right corner of the machine... make sure you know your own measurement volume and adjust the values accordingly. By Default it does Z first, which is likely what you want, but you can force it to run in different orders ( PCM manual explains all that)
This is one of the best ways to do this and one of my preferred.  The other is to use an inspection_end_pcm.txt to perform a stylus change (typically to masterProbe), which can also be accompanied with a positionCMM(axis,axis,axis,coordinate,coordinate,coordinate) (you can define the order of the axis travel.  Sometimes you want Y to move before X and vice versa)
Michael - If you have any features in your features tab that get measured, this will be enough to trigger the CNC END PARK POSITION
I used to use PCM to do a stylus system change in the inspection_end_pcm.txt file, but we ran into issues sometimes with it not behaving properly on some CMMs.  Drove me nuts. Same program on two DuraMax's running the same software, same firmware, 1 serial number digit apart.
1 CMM acted as you expected, did the probe change, then drove to the coded position, the other would drive to the limit of either the X or Y axis at it's current height, then take shortest path to the probe rack. So I gave up on that idea since it was all undocumented code anyway and was questionable benefit having it perform the probe change anyway.
  • 1 month later...
Apologies for the delay. We've recently undergone a major management change, and I've been tied up with other projects.
That said, I did try this, and Jeffrey is correct—it doesn’t execute the expected command.
After switching to 'Use position points' in the 'Run' screen, everything is now working as intended.
Thanks again for the help, everyone!
Unfortunately, we don't have PCM capabilities enabled. I sure wish this was included with Calypso by default. That is my only gripe with Zeiss.. Everything is behind a paywall.. but I understand. Many mouths to feed...
Thanks for the advice!
So, if Zeiss included all of their software options and charged more, people would say "we don't use that, why do I have to pay for it?"......
  • 2 months later...
Thanks all for this post! I just made a Probe Qualification program and I am having the same issue that
 was having! I am currently off the Contura G2 but will get to try this in the morning! I can run 10 probes start to finish and it always ends with hitting the +Z limit and triggering the red light. If I run just one probe, it does the same thing. I'll be looking for what he mentioned and see if it is just the needing to switch to "Use Position Points" that will fix my issue as well!
