Subtle change
I've been struggling with a program passing a simple type-1 GRR (1 part on/off the fixture 10x). The surface profile would not get below 20%.
The initial base alignment used a symmetry plane for its clocking. After several attempts and no improvement. I changed the clocking to a 3d
line form two circles. Surface profile now <10%. I had no idea such a minor change could have such a dramatic result.
I have had the same issue before with not having a robust clocking feature. Took me a while to learn how important that is when getting repeatable accurate measurements.
