Running the script produces an error message which unfortunately I cannot save or copy (made a screenshot)
It suggest to try the following pip install --use-pep517
I have added pep517.whl in Apps but that does not solve the problem
I do not understand what pep517 is and how to install it properly
The scripts runs fine in 2023
https://qualityforum.zeiss.com/topic/22066-script-no-longer-working-in-2025/
Hi
It seems the error is caused by installing the Python wheel mplcursors · PyPI (version 0.5.2). You might try to install a newer version of this wheel.
mplcursors is used together with matplotlib/matplotlib: matplotlib: plotting with Python. The versions of the Python installation used by ZEISS INSPECT (currently v3.9) and the Python wheels have to be compatible. When I just tried to install mplcursors in ZEISS INSPECT 2025, I got mplcursors v0.6, matplotlib v3.9.4 and many other wheels (due to package dependencies).
PEP517 is not a Python package, but a Python standard (see PEP 517 – A build-system independent format for source trees | peps.python.org). The error message above says that the command line package installer `pip` has a switch to apply this standard as an option (for older packages?).
Best regards,
Matthias
