[Yt...] Posted Thursday at 08:51 AM Share Posted Thursday at 08:51 AM Hi Would it be possible to change the reference system for a group of requirements at once, similar to the capability that already exists in the software in the Properties panel to set the tolerance for a group of dimensions at the same time? It would be great to know how this is achieved, and if not, I would be happy to present this as a new and useful option for cases where we wish to examine the impact of different reference systems on a particular requirement. Thank you Link to comment Share on other sites More sharing options...
[Jo...] Posted Thursday at 11:40 AM Share Posted Thursday at 11:40 AM Hi, Select the actual elements --> Properties --> General --> Alignment required Link to comment Share on other sites More sharing options...
[Yt...] Posted Thursday at 07:47 PM Author Share Posted Thursday at 07:47 PM Hi Thank you very much for your response, but you are referring to a different issue, which is the alignment required to be calculated for creating the element. I asked about something else, which is the datum system required for calculating profile tolerances, for example. I want to examine the measurement result against several reference systems and I would like to be able to make such a change easily and quickly for a group of measurements, all with a single command. Is this possible and currently supported in the software? Link to comment Share on other sites More sharing options...
[Jo...] Posted 15 hours ago Share Posted 15 hours ago Ok, I understand your question, but in your case I can't help you, I didn't find a solution 😕 Maybe some developer can help you, I think that's would be a great tool. Link to comment Share on other sites More sharing options...
[Na...] Posted 14 hours ago Share Posted 14 hours ago Hello, I think separate checks with a new datum system would be the easiest solution. Or you edit the used datum system, so it's based on other datums. -> this would keep report pages with the existing checks intact. A scripting solution is also possible but I'm not aware of another "clickable" solution. Link to comment Share on other sites More sharing options...
