[pg...] Posted January 20, 2025 Share Posted January 20, 2025 i have two concentric cylinders. Not complete cylinders. They have an Arc segments of about 40 degrees. i need to measure the distance between their diameters. How is this best done? thx in advance for your assistance! Link to comment Share on other sites More sharing options...
[Na...] Posted February 7, 2025 Share Posted February 7, 2025 Hi, you could depending on the data create two fitting cylinders and calculate the diameter difference with a user defined check, or you could create a general surface distance for example. Could you post an image of the problem? Nanno Link to comment Share on other sites More sharing options...
[Cl...] Posted February 10, 2025 Share Posted February 10, 2025 (edited) By your description it sounds like you should use Caliper Distance or Cartesian Distance. Edited February 10, 2025 Link to comment Share on other sites More sharing options...
