Scanbox Cylinder wall thickness?
i have two concentric cylinders.  Not complete cylinders.  They have an Arc segments of about 40 degrees.
i need to measure the distance between their diameters.  How is this best done?
thx in advance for your assistance!
  • 3 weeks later...
Hi,
you could depending on the data create two fitting cylinders and calculate the diameter difference with a user defined check, or you could create a general surface distance for example. Could you post an image of the problem?
Nanno
By your description it sounds like you should use Caliper Distance or Cartesian Distance.
