Output Data - vrs allocated alignment
I am using Local Best Fit Alignment on parts as well as RPS alignment to address warpage on parts. problem I am having is when I extract the data.. data is being extracted in whatever alignment is active on the part (i.e. parts are warped and my results are not correct)
Within properties I have assigned specific measurements to different LBF alignments, However when I review results in diagram format it is only extracting the data in selected alignment and not the assigned alignment from properties.  How can I extract data from assigned alignment all in one? as I need to automate the data extraction
Setting up local co-ordinate systems is the way to achieve an all in one table.  There used to be a knowledge base article how to.  Im afraid i dont know how to get access to these articles anymore , but id have hoped by getting into an online area within the zeiss quality suite.
