[Mi...] Posted January 23, 2025 Share Posted January 23, 2025 Hi all, does anyone know if there is a way (without PCM-module) to automatically export a custom csv-file with some data from last measured part for an intern BDE system? I think a text file would be ok aswell. It should include some user-input data and, most importand, a "final result" which gives an OK, NOK or ERR message to our system, plus the location and name of the report. We are still using an old Calypso 2016 version, so i'm not sure if it's possible to do that. It was not difficult to do this in ZEISS Inspect as you are free to programm any custom exports in python but i'm desperate to do this in Calypso or PiWeb. My best "workarround" was to export a text-file which is named by "part-nr; date/time; inspectionToleranceState("outOfTolerance")"... but that's not exactly what i need and does not fit to our BDE input. I'm looking forward to any ideas. Best regards Michael Link to comment Share on other sites More sharing options...
[Ma...] Posted January 23, 2025 Share Posted January 23, 2025 I think only txt file would be "Table file" or QDAS. For Table files there is even Merge file, but we are using only Table file - this will create 3 files ( headers, characteristics and actuals ) - for custom name/path you can edit that same as for PDF files Link to comment Share on other sites More sharing options...
[Mi...] Posted January 23, 2025 Author Share Posted January 23, 2025 Hi Martin, thx for your fast reply. Yes, it does export .txt files. The name and path can be edited as i need. But i do need a specific format as content in the file: (part-nr [user_input] ; date/time [YYYY-MM-DD hh:mm:ss.ssssss] ; path_to_the_report [*.pdf] ; result [OK,NOK,ERR];Order [user_input]) How could this be possible? Link to comment Share on other sites More sharing options...
[Ma...] Posted January 23, 2025 Share Posted January 23, 2025 If you need that format, then easiest way would be PCM. Otherwise some magic with BAT file and interpreter of table files. Link to comment Share on other sites More sharing options...
[Ch...] Posted July 27, 2025 Share Posted July 27, 2025 También puede agregar la ruta en el protocolo y le da la opción de cambiar la terminación del archivo a .txt. Link to comment Share on other sites More sharing options...
[DW...] Posted July 28, 2025 Share Posted July 28, 2025 Please sign in to view this quote. Best bet is to get the information out of Calypso in whatever format is available, and then manipulate that file with a PowerShell script into whatever the end result needs to be. Link to comment Share on other sites More sharing options...
[Ri...] Posted July 28, 2025 Share Posted July 28, 2025 Just create a Python script, and have it executed at the end via the end_report.bat 2 Link to comment Share on other sites More sharing options...
[Ri...] Posted August 1, 2025 Share Posted August 1, 2025 You could turn on Excel files, capture the open Excel file after the run and convert to a CSV with VBS. Link to comment Share on other sites More sharing options...
