[Ro...] Posted January 23, 2025 Share Posted January 23, 2025 Hi everyone, I’m currently measuring a large part where accessing certain areas from above isn’t possible with the long stylus required for internal measurements. All the measuring and probe changes need to be handled via PCM, as the external software might request the same measurements to be repeated multiple times. Here’s the solution I’ve come up with so far, which works, but I’m certain there’s a more elegant way to handle this: Stylus: Dummy (not in the rack) Stylus: Longthing (not in the rack) // -- get rid of current StylusSystem and put in DUMMY manually changeStylusSystem("DUMMY") // -- move short DUMMY over big part positionCMM(900,-2850,-5) // -- take out dummy manually and put in longthing manually changeStylusSystem("Longthing") // -- Do whatever measurements i need to do //-- Drop longthing inside the part and put in dummy manually again changeStylusSystem("DUMMY") // -- move outside the part positionCMM(900,-1000,-5) Ideally, I would like it to look like this: // -- get longthing via CNC changeStylusSystem("Longthing") // -- move it right infront of the big part positionCMM(900,-3050,-5) // -- drop longthing changeStylusManually("Longthing") // -- Function doesnt excist, thats just what i'd want to excist // -- Move inside the part positionCMM(900,-2850,-5) //-- manually put in longthing changeStylusManually("Longthing") // -- Do whatever measurements i need to do //-- Drop longthing inside the part changeStylusManually("Longthing") // -- move it right infront of the big part positionCMM(900,-3050,-5) // -- Put in longthing again changeStylusManually("Longthing") // -- now it can be put back via CNC and another Stylus can be get via CNC to do other stuff changeStylusSystem("Whatever") Link to comment https://qualityforum.zeiss.com/topic/22200-manual-stylus-change-via-pcm/ Share on other sites More sharing options...
[Mi...] Posted January 24, 2025 Share Posted January 24, 2025 Hello! Try this: cmmosCommand("TM") I haven't used it yet, so I don't know if it works properly. Link to comment https://qualityforum.zeiss.com/topic/22200-manual-stylus-change-via-pcm/#findComment-124990 Share on other sites More sharing options...
[Ro...] Posted January 24, 2025 Author Share Posted January 24, 2025 Danke Michael! Macht genau das was ich brauche!! Verhält sich ein bisschen komisch (wenn man auf abbrechen Drückt hängt sich das CNC-Programm auf) aber solange man genau das macht was man soll klappt es Problemlos. Link to comment https://qualityforum.zeiss.com/topic/22200-manual-stylus-change-via-pcm/#findComment-124998 Share on other sites More sharing options...
