New Gear Pro 7.2.0012_ K-Charts not reporting?
I downloaded and installed the latest versions of Calypso and Gear-pro on December 4th of last year.
I run my first gear-pro program yesterday and can not get the K-charts to show-up on the report.
The program was created and proven in 2018 and has not been run since that time.
I've got a help ticket going and they have logged in to look at it , but currently haven't been able to figure out why the K-charts are not showing on the reports.
Has anybody else had this problem?
Any ideas on what the problem might be?
The solution:
If you turn off the check mark for the K-Chart in the profile menu, turn it back on, and then hit apply, that fixes the issue. The K-Chart data is saved in the background, so you don’t have to put it back in.
Not sure, but it appears that there is something wonky with how the older programs are handled in the newer version, but doing as mentioned above fixes it.
Thanks to Applications Engineer Kyle Johnson for coming up with a solution.
Edited
  • 9 months later...
No I haven't updated to 2025 yet, still running 2024, but this is frustrating.
I don't run a lot of gears with K-charts but having to reset this after every run is crazy. Also, after deselecting the K-chart and then re-selecting it to make it appear, it changes the end of the profiles evaluation range and I have to reset it to :-(.
Hope to upgrade to 2025 soon and I hope this hiccup has been fixed.
so, turning it off and turning it back on fixes the issue ... confirmed ...😄
Thanks Owen and Zeiss !
  • Like! 1
