[An...] Posted January 26 Share Posted January 26 Gibt es in Calypso 2024 eine möglichkeit, eine Schleife über das Messprogramm zu legen, wo ich die Anzahl der Durchläufe über ein Eingabefeld steuern kann. Programm im Autorun starten, Eingabefeld ploppt auf, Anzahl der Durchläufe wir eingegeben, Programm läuft weiter. Link to comment Share on other sites More sharing options...
[Mi...] Posted January 28 Share Posted January 28 Guten Morgen Andreas, hast du eine PCM-Lizenz? Denn ohne, funktioniert dies - meines Wissens - nicht. Link to comment Share on other sites More sharing options...
[Ma...] Posted January 28 Share Posted January 28 If you want to just run program without evaluation ( protocols ), then i think you can do it without pcm and very easily. If you need protocols, then i'm affraid no without pcm. Link to comment Share on other sites More sharing options...
[Mi...] Posted January 28 Share Posted January 28 Please sign in to view this quote. Your're right, this can be achieved easily with a Prothead variable. 🙃 Link to comment Share on other sites More sharing options...
[Ma...] Posted January 28 Share Posted January 28 Please sign in to view this quote. You don't even need to fill that to start parameters ( headers ) - just right click on characteristic tab without selected characteristic and click loop. Then for condition to break just fill "LOOP1 == inquireNumber(TITLE)" and it should ask before run. Maybe it will ask everytime when it checks breakloop. In that case i would stick to adding into header that value. Link to comment Share on other sites More sharing options...
[An...] Posted January 30 Author Share Posted January 30 danke für die Info, leider wird so bei jedem durchlauf die Abfrage gestartet. Ich habe das PCM Modul bestellt, ich denke, so sind wir flexibler. Link to comment Share on other sites More sharing options...
