facing ACIS Socket failed issue
A little description would help more.
Do you face it for the first time? Tried restarting Calypso/PC? Did it work at least once or is it first try?
Is it planner or real machine switched to simulation mode?
Hi Martin I tried number of ways to solve this issue, restarted multiple changed system but getting  same issues. check attached snaps.
image.png.c85ae0528a67712dda08f09a620d894e.pngimage.png.d55813b6da714c1b506292153f2c54e8.png
Hello Vishal,
If you start CALYPSO without opening an Inspection, please check in the Task Manager if the Acis3x.exe is running:
it might be hidden within the vwnt.exe
If its not running it might be an IT issue, the Acis.exe sometimes gets blocked or deleted by firewalls or antivirus apps. Check the following path if you use CALYPS 7.8:
C:\Program Files\Zeiss\CALYPSO 7.8\bin\acis
If the Acis.exe is running please change the following settings in the NVIDIA System Settings:
Regards
Marcel
image.png.880de0f0cbf1871a978410f651735ecc.pngINVIDIA Global settings only one option is how in image 3D setting image.png.1366c9ebbcfefc8456d521da786e55c4.pnggimage.png.eab07abbaa7a07c21a513d09b638d3b9.pngINVIDIA Global settings only one option is how in image 3D setting
