[bh...] Posted January 30, 2025 Share Posted January 30, 2025 (edited) Hello, I have created a feature as a cylinder with two circle path as strategy. In the final report I am outputing the characteristic as Bore Cylinder. Anyway I could extract the two cirlce paths and output them a Circle. I know there are other ways to do this inspection but just want to understand if there is a way to extract a strategy and output it without measuring it again. Thanks Edited January 30, 2025 Link to comment Share on other sites More sharing options...
[Du...] Posted January 30, 2025 Share Posted January 30, 2025 You should be able to create a new circle feature, recall feature points and right click on the cylinder and click open and you should be able to choose the individual paths, then repeat as needed. Link to comment Share on other sites More sharing options...
[bh...] Posted January 30, 2025 Author Share Posted January 30, 2025 That was so helpful. Thank you. Do I have to check box (bottom of the dialog box) that says Re-evaluate feature Link to comment Share on other sites More sharing options...
[Du...] Posted January 30, 2025 Share Posted January 30, 2025 pretty sure you want to uncheck it before you click on the path as it may change your nominal dimensions. Link to comment Share on other sites More sharing options...
