Extract feature Strategy (Circle path) and output in the final report
Hello,
I have created a feature as a cylinder with two circle path as strategy. In the final report I am outputing the characteristic as Bore Cylinder. Anyway I could extract the two cirlce paths and output them a Circle. I know there are other ways to do this inspection but just want to understand if there is a way to extract a strategy and output it without measuring it again.
Thanks
  • [bh...] changed the title to Extract feature Strategy (Circle path) and output in the final report
You should be able to create a new circle feature, recall feature points and right click on the cylinder and click open and you should be able to choose the individual paths, then repeat as needed.
That was so helpful. Thank you.
Do I have to check box (bottom of the dialog box) that says Re-evaluate feature
pretty sure you want to uncheck it before you click on the path as it may change your nominal dimensions.
