Text input
Hello.
A simple PCM question perhaps:
I´m trying to create a dialogue where the operator needs to input a value to put in the protocol header. It is not allowed to be empty.
I tried something like this:
list=inquireText("Type a value")
setRecordHead("u_k0009_text",list)
if list
message("Value is empty, try again")
endif
Edited
wrong spelling
Play with this. Similar task - different header value. Also has a loop and cancel if they try to leave it blank 3 times.
It's a more complicated, but it clears the value at the start, and traps the operator to force them to fill it out or the program can't run. Can't trust people lol
//Asks for employee numbers and puts it in the header data. Requested by QA Supervisor, only for QA CMMs
setRecordHead("vda_signature","")
loopCount = 0
repeat
	setRecordHead("vda_signature",inquireNumber("Please Input your Employee ID to continue"))
	loopCount = loopCount +1
until  ((getRecordHead("vda_signature") <> "0") and (len(getRecordHead("vda_signature")) > 2)) or (loopCount == 3)
if (loopCount >= 3) and ((len(getRecordHead("vda_signature")) < 3)) then
	message("You must enter your employee number to continue, program will stop")
	cncBreak()
endif
Instead of (len(getRecordHead("vda_signature")) > 2) you could have getRecordHead("vda_signature") <> "" which means "Does not equal blank" since the first line sets it to blank....
if getRecordHead("u_OperatorNumber") == "" then
	repeat
	operator = ""
	operator = inquireText("Operator Number")
	setRecordHead("u_OperatorNumber",operator)
	until (operator) <> ""
	endif
//----------------------SHIFT--------------------------
if getRecordHead("u_Fixture") == ""
	repeat
	shift= ""
	shift = inquireList("CNC Fixture ID","1","2","3")
	setRecordHead("u_Fixture",shift)
	until text(shift) <> ""
	endif
  • 2 weeks later...
To prevent people being people you'd have to do selections from lists where you can, or use other languages to take advantage of regular expressions or check input vs a database...
A lot more involved, the need easily prevented by a Supervisor going out and questioning unacceptable inputs.
  • 2 weeks later...
inquireList prevents that.
With inquireText() - Thats not really a program problem.  Thats a training problem.  Good luck with that. 😂
