Text input
Hello.
A simple PCM question perhaps:
I´m trying to create a dialogue where the operator needs to input a value to put in the protocol header. It is not allowed to be empty.
I tried something like this:
list=inquireText("Type a value")
setRecordHead("u_k0009_text",list)
if list
message("Value is empty, try again")
endif
wrong spelling
Play with this. Similar task - different header value. Also has a loop and cancel if they try to leave it blank 3 times.
It's a more complicated, but it clears the value at the start, and traps the operator to force them to fill it out or the program can't run. Can't trust people lol
//Asks for employee numbers and puts it in the header data. Requested by QA Supervisor, only for QA CMMs
setRecordHead("vda_signature","")
loopCount = 0
repeat
	setRecordHead("vda_signature",inquireNumber("Please Input your Employee ID to continue"))
	loopCount = loopCount +1
until  ((getRecordHead("vda_signature") <> "0") and (len(getRecordHead("vda_signature")) > 2)) or (loopCount == 3)
if (loopCount >= 3) and ((len(getRecordHead("vda_signature")) < 3)) then
	message("You must enter your employee number to continue, program will stop")
	cncBreak()
endif
Instead of (len(getRecordHead("vda_signature")) > 2) you could have getRecordHead("vda_signature") <> "" which means "Does not equal blank" since the first line sets it to blank....
if getRecordHead("u_OperatorNumber") == "" then
	repeat
	operator = ""
	operator = inquireText("Operator Number")
	setRecordHead("u_OperatorNumber",operator)
	until (operator) <> ""
	endif
//----------------------SHIFT--------------------------
if getRecordHead("u_Fixture") == ""
	repeat
	shift= ""
	shift = inquireList("CNC Fixture ID","1","2","3")
	setRecordHead("u_Fixture",shift)
	until text(shift) <> ""
	endif
  • 2 weeks later...
I think I have tried both Jeffs and Micheals methods in the past from one of my posts.
Then the operators just started putting in dashes and or dots. 😑
To prevent people being people you'd have to do selections from lists where you can, or use other languages to take advantage of regular expressions or check input vs a database...
A lot more involved, the need easily prevented by a Supervisor going out and questioning unacceptable inputs.
  • 2 weeks later...
inquireList prevents that.
With inquireText() - Thats not really a program problem.  Thats a training problem.  Good luck with that. 😂
