[Ju...] Posted February 5, 2025 Share Posted February 5, 2025 Hello All, I generally make a table report of the entire lot when I finish it. Whenever there is a position characteristic with MMC it takes the last measured tolerance and applies it too all the individual parts across the row. This causes parts to be displayed as passing or failing based on this value instead of based on their individual measurements. Has anyone had this issue or know a workaround. I don't care what the tolerance says, just need the values to be highlighted as pass or fail. Based on the individual reports, numbers 1, 5, 6, and 7 should be red, but it is using the tolerance from number 20 and passing everything. Link to comment Share on other sites More sharing options...
[na...] Posted February 6, 2025 Share Posted February 6, 2025 Please sign in to view this quote. Hi, Justin. I see that as a great improvement and I suggest you to put it under PiWeb ideas on the portal -> https://portal.zeiss.com/my-voice/software/metrology Link to comment Share on other sites More sharing options...
[To...] Posted February 6, 2025 Share Posted February 6, 2025 (edited) Please sign in to view this quote. Isn't it more of a bug fix or a limitation of the table format? Edited February 6, 2025 Link to comment Share on other sites More sharing options...
[Ju...] Posted February 7, 2025 Author Share Posted February 7, 2025 I talked with Zeiss and it seems like this is a normal occurrence. It will always use the last measurement taken for any 0 MMC tolerance, as it is stored globally. According to them there is no way to change it to make it appear pass or fail either for Table reports. Link to comment Share on other sites More sharing options...
