[An...] Posted February 7 Share Posted February 7 I am working on setting up a trend chart and there is a bunch of bad data I don't want used. I can use direct measurement and pick what I want but that is a huge hassle every time. I moved the ZMP files out of the directory but piWeb is still finding this measured data somehow. Is piWeb storing data its data locally? Link to comment Share on other sites More sharing options...
[To...] Posted February 7 Share Posted February 7 Go to Resources > Results to File > PiWeb Reporting > Configuration > Managing Measurements and Delete or Block measurement that you don't want in your data set Link to comment Share on other sites More sharing options...
[An...] Posted February 7 Author Share Posted February 7 Please sign in to view this quote. Thanks Tom Blocking made no change in piWeb data selection Deleting them did but I would really rather avoid doing that. Link to comment Share on other sites More sharing options...
[To...] Posted February 7 Share Posted February 7 Please sign in to view this quote. There may be a setting to not allow blocked records. Let me see. Link to comment Share on other sites More sharing options...
[To...] Posted February 7 Share Posted February 7 When the report opens, go to Navigation > Show Measurement Selection or (F6) Measurements tab, click on the "not equal" sign and select "equals" sign. You could make that the default setting if you intend to always block runs, but I believe it would become a custom PiWeb template. Link to comment Share on other sites More sharing options...
[DW...] Posted February 17 Share Posted February 17 Please sign in to view this quote. Please sign in to view this username. The PiWeb database for each program is here - C:\Users\Public\Documents\Zeiss\CALYPSO\workarea\PiWebReportingDatabases This is the default location, where you will see the .dfm files. Inside the .dfm files, are everything related to measurements for each program. Here is my suggestion - Find the correct database by its name. Copy the database to your desktop. Delete the database from the default location. Go back in Calypso, and do a subsequent measurement of multiple measurements (put your .zmp files back in their location first). Load the measurements you want, click OK. PiWeb will create a new database with only the measurements you selected. If this doesn't do what you want, drag the old database back into the default location and it will overwrite the new one with all the old values. Link to comment Share on other sites More sharing options...
