Cilinder mesh fitting
Hello,
I need to fitting element for a nominal cilinder, but sometimes the mesh is far from the nominal and the software doesn't recognize it.
I tried to change the parameter max distance, but when I disable "Compute Max distance automatically" it lose the link with nominal element.
I can pick the cilinder by select the mesh region manually, but I don't know if it will lose the parametric.
