[Ca...] Posted February 10, 2025 Share Posted February 10, 2025 The process protocol is designed for 50 runs by default. Can it be changed to 10 runs? Otherwise, after 10 runs, 40 blank pages will be created. Link to comment https://qualityforum.zeiss.com/topic/22376-process-protocol/ Share on other sites More sharing options...
[An...] Posted March 12, 2025 Share Posted March 12, 2025 That does not sound right. If you only have 10 runs it will only load the data you have and not generate additional pages unless the proces protocol was edited in someway to make those additional pages. I would maybe see if you can pull up fresh process protocol template or I would also try experimenting with the Trend protocol. It is a sleeker version of the process protocol that I prefer if all you want is trend lines. If you for example have more than 10 runs and only want to display a select 10, you could eitehr use the navigation-Show measurement (F6 shortcut) option when in PiWeb monitor or experiment with approval/rejected option to use as a sudo filter of what you want to show in the process protocol. See link below to set that up: https://portal.zeiss.com/knowledge-base?id=444493 Link to comment https://qualityforum.zeiss.com/topic/22376-process-protocol/#findComment-128187 Share on other sites More sharing options...
