[To...] Posted February 11, 2025 Share Posted February 11, 2025 (edited) I have 2 inline cylinders with the following notation. Any thoughts on the lower tier? Di I create a position of cylinderC to cylinderD and then vice versa? I would have preferred to see each cylinder have a datum reference then use a positions of each cylinder to C-D but that is only wishful thinking. Edited February 11, 2025 Link to comment Share on other sites More sharing options...
[Ja...] Posted February 11, 2025 Share Posted February 11, 2025 If I am visualizing the inline cylinders you are describing correctly and your goal is to use a CMM and Calypso to measure this callout you may have some luck using the "Step Cylinder" function under "Features" - "Special Geometries" and that may take some of the guess work out of interpretation. That said I haven't played around with Step Cylinder too much so take my suggestion with a grain of salt. Link to comment Share on other sites More sharing options...
[Ri...] Posted February 11, 2025 Share Posted February 11, 2025 If they are supposed to be the same size, what I've done in the past is create a Max Inscribed Cylinder from all of the points, used that as the datum, and then evaluated the Position of the individual Cylinders back to that Max Inscribed Cylinder. If you are using the new GD&T you don't have to do this at all. This would just be a Sim Requirement. Link to comment Share on other sites More sharing options...
[Ha...] Posted February 11, 2025 Share Posted February 11, 2025 Please sign in to view this quote. You can set up the position for the lower tier in Calypso. https://portal.zeiss.com/knowledge-base?id=1551507 Link to comment Share on other sites More sharing options...
[To...] Posted February 12, 2025 Author Share Posted February 12, 2025 Please sign in to view this quote. Thank you. If cylinders are same size, can I use a cylinder or does it have to be a step cylinder? Link to comment Share on other sites More sharing options...
[Ri...] Posted February 12, 2025 Share Posted February 12, 2025 Please sign in to view this quote. See my comment above Link to comment Share on other sites More sharing options...
[To...] Posted February 12, 2025 Author Share Posted February 12, 2025 (edited) UPDATE Not sure if I asked the correct question. After re-reading the note, I don't know if they are including all 4 cylinders Edited February 12, 2025 Link to comment Share on other sites More sharing options...
[To...] Posted February 12, 2025 Author Share Posted February 12, 2025 Please sign in to view this quote. I read it after I posted my questiion. DOH I thought they were the same size but they aren't. DOH DOH Link to comment Share on other sites More sharing options...
[Ri...] Posted February 12, 2025 Share Posted February 12, 2025 Yeah. I think they are intending the top set to be evaluated separately from the bottom set. And yeah, looks like Step Cylinder it is. Link to comment Share on other sites More sharing options...
