Creation of a planar tolerance zone for true position requierment of slotted tertiary datum feature
Hello
I need some help regrading the true position of the element C.
According to the drawing I have to inspect to symmetry plane of the slot relating to A|B, but due to the fact that A is perpendicular to C, A|B datum system dose not containing the needed information to provide me a planar tolerance zone, but only a circular one because it is just a point over a plane.
What is the best steps that are needed here so I will be able to get a planar tolerance zone?
A circular zone contain also the deviation of the 94.5mm and I want to neglect it.
As for now, I constructed two rotational planes. First 90 degrees for A around the CAD X axes when the point is B and then 25 degrees around the B axes.
In this way I acquired a plane in the appropriate direction, where, although its directions are nominal, its axis of rotation is obtained from actual scanned data.
Is this a proper and correct way of operating?
Thank you
  • 3 weeks later...
I am not sure of options on INSPECT, but here you have spatial as plane A and origin as circle B - are you able to fill only whose two elements into TP datums and get result?
You can set tolerance to X or Y only, because there is no need for second tolerance ( missing ⌀ so rectangular tolerance band, but here is not used on center, just for symmetry ).
Theoreticaly you can do normal alignment where you will use B-C and planar and B as origin.
I need a planar tolerance zone according to the slot direction so I will be able to control the angular position of this element.
The A|B system is just an axis over a plane and it dose not containing this information.
I can't construct B-C by C and then check C against itself.
So I asked regarding the additional nominal construction needed here for this true-position request.
