Accuracy of T-SCAN HAWAK 2
Hello
I have a T-SCAN HAWAK 2
I calibrate the scanner every morning
And the accuracy of the scanner is good in the morning but by the evening and the temperature difference is 3 degrees Celsius
The device becomes inaccurate and has an error of about .05 MM for about 200 mm
If you have large temperature fluctuations you should perform a quick HyperScale Recalibration. The bar is located in the case. This is the intent of this process. It's extremely quick too.
Hard to say because I don't think the tech specs list anything like a CMM does for allowable temperature change. I would just say that it's probably just a good idea to do the hypserscale recalibration before each scan - I believe this can even be added to your template if you'd like.
  • 5 months later...
Hello Ali,
When you calibrate in the morning you set the temperature in the software, then temperature changes about 3 degrees. You should calibrate again and set the temperature that you have in the evening.
