[Da...] Posted February 12, 2025 Share Posted February 12, 2025 (edited) I have only just started playing around with saving PDFs. I found the steps to have it automatically save a PDF of the PiWeb report, and have it set up to save it by program name/date/time. I tested it out, and it created the folders and saved the pdf as expected. We have a few parts with features that are very finicky, and so whenever they are out of tolerance by a couple of tenths, I will re-run just that feature and sometimes it will change to in tolerance. I tried this, and it did change to in tolerance, and I was able to view the updated report on my screen, but it did not save a new pdf report or override the first one. I was able to click save and override it manually, but is there a way to make it do that automatically? Edited February 12, 2025 Link to comment Share on other sites More sharing options...
[Jö...] Posted February 13, 2025 Share Posted February 13, 2025 Hallo Darci, ich Hoffe ich habe dich richtig verstanden, und Du willst eine Nachträgliche Auswertung machen. Dazu gehst du oben im Menü auf CNC und wählst dort Nachträgliche auswertung aus. Dann wird dir eine neue Auswertung mit neuem Protokoll erstellt. Link to comment Share on other sites More sharing options...
[Ma...] Posted February 13, 2025 Share Posted February 13, 2025 If you are running that program in Autorun, then you probably don't have checked PDF for run in programming mode - or you hit F9 ( run selected features ) which will not bring header table for new start - so no pdf will be created and no protocol will be shown. So which state you have? Have you selected feature/characteristic and clicked on button "Run" - selected run "Actual selection" and protocol is shown Have you selected feature/characteristic and clicked F9 ( "quick launch" ) - no other selection and no protocol shown Link to comment Share on other sites More sharing options...
[Da...] Posted February 13, 2025 Author Share Posted February 13, 2025 Please sign in to view this quote. Jorg, Thank you! Link to comment Share on other sites More sharing options...
[Da...] Posted February 13, 2025 Author Share Posted February 13, 2025 Please sign in to view this quote. Martin, I don't know what Autorun is. But I have both ways and the new protocol is shown as you said but it does not save it as a pdf. What Jorg suggested works but if you know how to make it save automatically after "Run" - "Current Selection" I will do that. Link to comment Share on other sites More sharing options...
[Ma...] Posted February 13, 2025 Share Posted February 13, 2025 Well Autorun is CNC run ( there is dedicated forum for that ) I have saved template program for new programs where i have all setup - so i don't know for sure what needs to be set, but: there is window where you can select PiWeb protocol - click on PDF icon to be checked there is window where you can set to store measured actuals, pdfs, QDAS and others - there set PDFs to on when you are starting to run measurement ( that window where you are selecting what run you want, max speed and alignments ) there shoud be enabled or checked PDF checkbox I'll try to post screens when i'll get to work. Link to comment Share on other sites More sharing options...
[De...] Posted February 19, 2025 Share Posted February 19, 2025 (edited) Afternoon Darci, Martin nailed this one on the head like always. Right-click > Execute or F9 on your selected feature to be measured. Once a new actual has been recorded, open the run menu and confirm the following settings are selected. When we confirm the run, a new PDF will be populated with the original values, and your newly executed feature results. Edited February 19, 2025 Link to comment Share on other sites More sharing options...
[Je...] Posted February 20, 2025 Share Posted February 20, 2025 Please sign in to view this quote. The industry term for this practice is "Greening" 😮 Link to comment Share on other sites More sharing options...
[No...] Posted February 20, 2025 Share Posted February 20, 2025 Please sign in to view this quote. When we went to the Calypso class long ago and the instructor talked about the different types of reports, the first question my - now retired - colleague asked was "Is it editable?" 😂 Link to comment Share on other sites More sharing options...
[Ma...] Posted February 20, 2025 Share Posted February 20, 2025 Please sign in to view this username. Looks like it's same everywhere 😄 I've faced once a similar situation from head of QA. Link to comment Share on other sites More sharing options...
[Lu...] Posted February 20, 2025 Share Posted February 20, 2025 Please sign in to view this quote. Is "Greening" a bad thing? My apologies if it that is a dumb question I am new to cmm/metrology. Link to comment Share on other sites More sharing options...
[Ma...] Posted February 20, 2025 Share Posted February 20, 2025 Please sign in to view this username. well if you have problematic program / part, then you can not easily avoid this type of editing program. But only if you are doing correction withing strategy / recalled points. Editing program just to make it a "good" part is bad approach. Link to comment Share on other sites More sharing options...
[Lu...] Posted February 20, 2025 Share Posted February 20, 2025 Please sign in to view this username. I appreciate it thanks, i will often rerun parts that show out of tolerance to see if it was a fluke so I just wanted to double check, thanks. Link to comment Share on other sites More sharing options...
[Je...] Posted February 20, 2025 Share Posted February 20, 2025 (edited) Please sign in to view this quote. Luke, you ask a terrific question, and no apology is necessary. From my perspective, if re-running a part is done to increase plausibility in a measurement result, then it is a value-added activity. However, if re-running and overwriting an existing report is done simply to get a part to pass, then this behavior should be called into question. So, to answer your question: the underlying motivation should be considered. Our job as metrologists is to provide a trustworthy, stable result. Pressure to pass parts and bias can often compromise the stability of a measurement process. It's our job to keep things as scientific and objective as possible. Edited February 20, 2025 Link to comment Share on other sites More sharing options...
[Lu...] Posted February 20, 2025 Share Posted February 20, 2025 Please sign in to view this username. Thank you for the advice, I appreciate it. Link to comment Share on other sites More sharing options...
