Multiple Single Segment Position for a Single Hole
So, I have a scenario where I have a multiple single segment position callout for one hole in a part and need to understand the best practice for programming it. The top tier is pretty straight forward. I measure the hole as a cylinder and the choose the true position characteristic and select datum A (primary), datum B (secondary), then datum C (tertiary). The second tier I am not so sure about. Since it is only going back to datum A and no other datums I know that it can or should be able to rotate around A and translate along A. I have done this before for a pattern of holes but never a single hole, so I am not sure if the method or strategy is the same. I have attached a crude napkin sketch of the part and apologize for the lack of detail, but my company's policies do not allow me to share the original drawing or images of it.
20250213120434616.pdf
My result for the first tier is .0248" The result of the second tier is coming in at .0256". Not sure why this would be worse as it is not as constrained as the first tier. Maybe I am looking at this wrong. I would have thought that number would have been significantly lower than the first tier.
 Just to clarify - do you have your datum A and B as symmetry / symmetry plane? The way you draw datums A and B incline to be used as symmetries.
For second tier - just fill all three datums with datum A - watchout for (P) settings and selection based on norm you work in.
I would use symmetry plane for datum B too instead of point - you have to use it's rotation - datum C will give you only position - it should not give you anything else.
How long is that hole? This can help.
You can also investigate how are vectors looking like for datums and cylinder ( intersections, caliper distances, ... many ways to investigate ).
So, you have a rectangular 'saddle', where the datum A is the center-line between the 2 'legs' of the 'saddle', datum B is the center-line of the square hole in the top, perpendicular to the datum A center-line, and datum C is the planar surface on the top, that the square is cut through.
Next, you have a hole on the (if you set this up as A=x, B=y, and C=Z) which is not dimensioned, but it looks like it might be at X=0, Y is a negative number, and Z is also a negative number. And yet, A is set up as the primary datum, and C is the tertiary? Very odd.
If my ascertains are correct, you will be measuring the position in the Y,Z axis for the .030, and will be just calculating the .015 as perpendicularity to the A-plane, in which an MMC callout is pointless and incorrect.
 the hole is .440"-.446" in diameter and is only around .119" deep. Also, in a previous comment, you mentioned to watch out for (P) settings and selection based on norm you work in. What are you referring to there?
Edited
Since length of cylinder is 0.119" ( cca 3mm ) then i woul measure that as circle. I think you have problem with calculating vector ( cylinder axis ).
Look at that.
On mine version i have selection for cylinder in TP where you select (P) or feature with not straight lines - that would be like that - (P) will evaluate as nominal cylinder length, otherwise it will evaluate as measured length.
That (P) is often used for evaluating threads - projected tolerance zone
Yeah - that would be useless.
You can create new alignment with that datum A as primary - just this, nothing more is needed and recall that cylinder into this new alignment - it should tell you, that problem will be Y/Z X/Z angles.
Having .0256 ( thats 0.65mm ) deviation should be that vector.
Have you used symmetry plane or symmetry from planes? Using symmetry plane when you don't have same opposing points can be bad - using symmetry from planes will not affect that.
