Upgrading Calypso from 7.0 to 7.8
Hello all,
This note makes it sound like I can't upgrade to 7.8 without buying a new license? I was just wondering if anybody could clarify what is needed, because I don't see anybody else having these issues when I search for help. Right now I'm going from 7.0 to 7.6, so I can have all 3 of my Calypso installations have the same version, but I'd like to update them all to the latest software if possible. Can anybody shed some light on this? Thank you!
Hi Zachary,
If you have an active Software Maintenance Agreement (SMA), you can request a license update by visiting the following link: ZEISS License Update Portal.
Once you have requested the update, you will be able to run CALYPSO 2024 after activating the entitlement ID using the ZEISS License Management Tool (ZLMT).
For more detailed information, you can refer to this Knowledge Base Article.
Lucas, I was able to get Calypso 7.8 installed and working on one computer, but I can't get our other CMM or the offline seat to work. I did the same exact process as I did to the one that works, but now I'm running into issues.
