XXT TL1 to XXT TL3
We are looking at upgrading the TL1 head to a TL3 on one of our O-Inspects as a technician noted that the TL1 appeared to be near it's end of service life. I have a question regarding this that I didn't think to ask while the tech was here. What is the process for this swap? The tech mentioned the swap itself was pretty straightforward, so is it really just swap heads, move the stylus systems to TL3 plates, requalify and then we are good to go?
Thanks in advance.
https://qualityforum.zeiss.com/topic/22496-xxt-tl1-to-xxt-tl3/
Yes, new head and new plates.
Take note of the specs for each head. There's TL1, 2,3,4 and all have different reasons why you pick them. The TL3 for example has a greater weight capacity and able to use longer radial probes.
If you don't need that, you might be better off going TL4 if that suits your needs better.
There's better versions of this chart but this is the one I could find quickly.
https://qualityforum.zeiss.com/topic/22496-xxt-tl1-to-xxt-tl3/#findComment-127201
